Hi everyone,
I’ve built a plugin that adds a thermal camera to the U1. It streams a Thermal Master P1 USB thermal camera into Fluidd, next to the regular camera, and it’s available now in the Bespok3d app.
What it does
- A live thermal camera tile, with the hottest and coldest spots marked and a temperature ruler.
- An interactive viewer: point at anything to read its temperature, measure a region, place spot markers, zoom, save a still, or record a clip.
- A thermal timelapse of every print, one frame per layer, saved next to the U1’s own timelapse on Fluidd’s Timelapse page.
- Six palettes and four colour scales, and an automatic switch to the camera’s wide range when a hot nozzle comes into view.
What you need
- A U1 with Bespok3d.
- A Thermal Master P1 USB thermal camera. The P3 should work through the same code, but it hasn’t been tested on a printer yet.
Installing
- In the Bespok3d app, find Thermal Master. It’s a release candidate for now, so if you don’t see it, set the app to show release candidates.
- Install it, and plug the camera into the U1’s USB port.
- Open Fluidd: the thermal camera appears with your other cameras. The plugin’s settings page is at
http://<your-printer-ip>/thermal/.
Good to know
- It runs on the printer itself, with no custom firmware and no terminal work.
- It’s light when nobody is watching: under 5% of one core with nothing open, and nothing at all with the camera switched off. With a dashboard tile open, it uses about 42% of one core, and the settings page shows its current share.
- The thermal timelapse shows in Fluidd, not in the Snapmaker app, which only lists the printer’s own recordings.
- The U1 has a single USB port, so the camera takes it unless you use a powered hub.
Links
- Documentation, with every setting explained: B3_ThermalMaster/plugin/doc/README.md at main · Bespok3d/B3_ThermalMaster · GitHub
- Source and issues: GitHub - Bespok3d/B3_ThermalMaster: Thermal camera support for Bespok3D · GitHub
It’s a release candidate, so feedback and bug reports are very welcome, here or on GitHub.
Disclosure: Thermal Master supports this project with hardware.
