It occurred to me that the heated bed is magnetic, and I have lots of ferrous material in the shop. The torque on the bed should be pretty low, so I should be able to hold it in place with some steel bar. As a bonus, the steel frame should transmit additional heat to the glass bed, given sufficient warmup time.
First, low-tek version is just some 3/4" weld steel, roughly same height as the glass bed:
I drilled 2mm holes and made some copper clamps to hold the glass bed in place. I just happened to have some lengths of copper bar from an Online Metals protobox that were going to waste, and itās easy to shape copper with a file if need be. I donāt have the clamps on yet (and may not even need them) becauseā¦
I stuck the standard sheet on top. The steel conducts enough magnetic force to hold it in place, but I used to magnets to sandwich the steel bar and the spring steel sheet to the bed. I can do calibration, remove the sheet before setting the Z offset, and be done with it ⦠I hope.
Fallback plans (besides the clamps) in case the glass moves too much:
add some side pieces (could swear I had weld steel that sizeā¦)
more stronger magnets
drill the steel bar so that it can bolt to the mounting holes - one of the bars will have to use a short slot so the bars can be snugged up against the glass
weld tabs at the corners of the steel bar so that the glass plate registers against resulting corners
Realistically, Iāll probaby stop after more-stronger-magnets and go back to the drawing board.
EDIT: definitely going to drill the front bar to bolt it to the heated bed. When homing with the magnet-sandwich removed, the bar slid around because the bed is so warped, the only point of contact is the middle. Now this bar aināt precision ground or nuthing, but I slipped a 0.175 feeler gage under it at both corners, and that just aināt right. On the plus side, maybe the steel will pull the bed out of warp ![]()
OK, end digression. I know thereās a glass-bed frame somewhere on the forum that I should be posting this in, instead
