We say the same again, I think. 2 mm wavelength, Spatial frequency k is = 0.5 mm^-1.
Then the ringing spatial frequency vs speed is k = f / v. It seems silly, but this is useful later graphing the resonance versus speed.
Ah, now I am with you. You think in frequency, I tend to always think in wavelength because I can measure the latter ![]()
Yes! My brain has both after measuring resonances in Hz but also mm but also speed and⌠Yeah. ![]()
I found the broken stepper (from the x axis), took it apart and compared it with an older stepper that I still had lying around.
While the basic design is probably the same for all chinese NEMA 17 steppers, the Mocotech seems quite cheaply made in comparison to the other one:
All in all, numerous chances to get some kind of repetitive error.
Maybe. The Moons motors I ordered came quite recommended on the Prusa forums. Granted theyâre 0.9 deg, but I didnât see a big difference.
Apologies for not posting the data yet. The holidays are upon us, and some attention needed by the family besides. I have not forgotten though!
No problem at all - same here X-D
When it comes to the steppers: since
I actually do put some hope into the thought that replacing the Y stepper might do some good, even if it means some additional work since the Y stepper is anything but standard with its max. 40mm body length, 8mm dual shaft and 197mm long primary side.
Luckily, I had bought a full set of replacement steppers when the X axis stepper failed, so I do have a stepper that I can play around with. The only question is : which dual shaft stepper should I try?
Edit: since there are not too many biaxial steppers out there which fit and are easily available, I ordered an OMC 17HS16-2004D now. Letâs see how that one compares to the original one - the torque curve calculator I have says it should be a bit better for the roughly 2kg of Y gantry mass the J1 has, and the OMCs had proven to be nicely silent on my old printer ![]()
Yes! The x stepper is not actually so bad itâs an obvious problem. The artifacts from the Y motion are much more noticeable to me.
I actually have most of the hardware I need to modify the Y axis with 0.9 steppers. Special couplers and all.
Just, after seeing no dramatic improvement in the x data, I decided to stop and think about the bigger undertaking. I did most testing on x simply because it was easier, aside from firmware tweaks for microstepping and spread cycle hybrid mode.
Iâm eager to hear your results. I found biaxial stepper and ordered a stiff coupler and some additional shaft to extend and cut as needed.
Not tried yet though!
EDIT to add, my J1s is working normally again at least! Replaced the main board a week ago. Iâm still laughing that I did all this work on my printer, then restored it, THEN it breaks by my clumsy hands.
I went for two (radially rather stiff) flexible shaft couplers - my stomach feeling that a bit of angular flex might not harm, the Y drive of the J1 is mechanically overdefined. Letâs see what that does ![]()
Those flex couplings can have a lot of give. May not be very precise. And possible the two sides donât stay in sync. If theyâre the spiral type.
But on second thought⌠One thing I was also going to try was adding vibration dampener to the motor mount. Granted itâs stiffer than I expected, but I wonder if flex couplers would achieve similar.
You are right, the cheap spiral type is not that good and might have not enough radial stiffness as well for the J1. I went for one with a⌠somewhat zick-zaggy cut (donât know the correct english name for those, it is the GMT FACMS20-5-8) instead.
You will need to remove the stiffening rib next to the stepper to do that, which is why I dropped that idea for now.
Okay, new stepper is in and TMC settings are updated. Draws more current, sounds very slightly less noisy, has more power and slightly reduces the artifact depth on the âworst-case edgeâ of my test part - but it does not have a really significant impact.
Since the original J1 board already seems to have heat issues with the TMCs (otherwise Snapmaker would not glue heat sinks on them even if TMC says that cooling their stepper drivers must be done from the PCB and adding sinks onto the top of the chips not make sense), I would vote for not switching the stepper on an original J1, even if I will leave mine in the printer now since it will make my life easier if I ever want to replace that one.
I noted however that if I put my finger on the stepper, I do not feel any vibrations any more, while I well feel them if I put my finger onto the side of the top frame of the printer, directly above the place where the linear rod is screwed on.
For what itâs worth (although youâve completely disassembled yours also), Snapmaker also sinks their drivers from below. Thereâs a thermal pad under the board, and below it the aluminum chassis has a polished extrusion that rises up to turn the aluminum body into a big heat sink for the drivers.
Pretty clever touch actually.
Hm⌠the basic idea behind that is indeed clever, but the way it is done is a typical case of ââŚdid not think this throughâŚâ
(Additionally, my stomach feeling says they probably made the aluminium down there too thin for a decent heat sink, and the complete lack of air flow due to warm air getting caught in the dent in the printer bottom probably does not help either. But that is something I did not check in detail, therefore it is not in the above list.)
My solution when replacing the whole controller was to throw out the noisy small fan in the back, add a larger but silent (and really temperature controlled - not only on-off) radial fan blowing outwards right next to the controller board and a printed air guide right below the PCB that makes sure all the air drawn by the fan flows along the underside of the PCB where it is needed. Result: same amount of fans, less noise, and the need for both the âcase heat sinkâ and the added heat sinks on top of the steppers is eliminated.
Hmm. On point 1, I did not think it was too thick when I changed my board. It actually took me a second to recognize what it was. Since my replacement board didnât include new padding I peeled the old one and reused it, but tore it twice trying due to its thinness. Fortunately it was sculptable enough I was able to shape and close the small gaps just fine.
I do want to replace that little chassis fan though. Itâs hard to believe that little thing moves much air for all itâs noise. But also, thereâs quite some thermal mass to the air and the metal chassis, so I donât worry about this much.
I have certainly seen at least one, far worse setup for driver thermals that never had trouble. (A Klipperized Ender)
Hm, the one on mine was at least 2mm thick. It still tore, but definitely not due to its thickness but rather because it stuck like hell to the PCB.
Those things are/were added to some Raspi 3 aluminium cases that use the case for passive cooling. And they usually take great care to use max. 1mm (better 0.5mm) thick thermal pads since doubling the thickness only lets half the thermal energy pass through. That together with the relatively bad thermal conductivity these pads have (around 6âŚ12W/mK compared to 400W/mK for copper) and the small size of the TMCs results in a rather bad heat transfer.
