In the background of this image, the largest part (Hose Blank Off Plate.stl) is causing Luban to return said error when trying to generate gcode - specifically when trying to generate supports. Loading that STL into its own workspace yields the same error.
When rotated into a vertical orientation, no error. I’ve repaired the STL to no avail. What does Luban want here?
PS that part is an attachment to the Artisan hose that will fit into a standard American sliding window. Take it if you want it.
