Where can I buy more cylindrical Epoxy Tooling board?
I just got the rotary module. It’s really cool. I’d like to find where to buy more of the Epoxy Tooling board you include. I have found a few sources on amazon but nothing is cylindrical so cutting it to shape will be an issue.
Do you have any bulk sources for Epoxy Tooling board or will you start setting it in the “martials” section of the snapmaker site?
Also another random question; if I’m using hardwood like maple or walnut, do I use the same “step down” setting of 10mm and only alter the work speed? everything else between Epoxy Tooling board and hardwood stay the same?
Thanks!
