# V4.12.0 toolpath issue
**URL:** <https://forum.snapmaker.com/t/v4-12-0-toolpath-issue/35888>\
**Created:** [May 18, 2024, 4:41pm UTC](https://forum.snapmaker.com/t/v4-12-0-toolpath-issue/35888 "2024-05-18T16:41:40Z")\
**Showing post:** 4
**Author:** ![EASchmidtE](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.snapmaker.com/easchmidte/32/26580_2.png) [@EASchmidtE](https://forum.snapmaker.com/u/EASchmidtE)\
**Post date:** [May 19, 2024, 6:13pm UTC](https://forum.snapmaker.com/t/v4-12-0-toolpath-issue/35888/4 "2024-05-19T18:13:11Z")
Okay, I found this thread,
[Create Path in CNC processing no longer works](https://forum.snapmaker.com/t/create-path-in-cnc-processing-no-longer-works/35259)
It had the 99%solution to the problem if you’re running Windows. If you’re running MacOS, the file that needs to be deleted, not modified, machine.json, can be found in the following directory:
/Users/EASchmidtE/Library/Application Support/
This path had to be accessed through the Terminal window using what little knowledge I have about a Command Line interface. Trying to access this folder through the GUI Finder on my MacBook did not work because the Library folder is hidden. I used the list ‘ls -la’ to display the contents of each folder. Then, I used the change directory ‘cd’ to change into the folder that I wanted to go to until I found the file.
I tried to modify the file at first by removing the server name like the above thread said, but it didn’t work. Once I deleted the machine.json file, I was able to get past the error screen and create the toolpath for my project.
_[View the full topic](https://forum.snapmaker.com/t/v4-12-0-toolpath-issue/35888)._
