Update on Snapmaker Orca V2.4.1 Windows Security Warnings
Hi everyone,
we’d like to share an update on the security warnings some users have encountered when installing Snapmaker Orca windows_installer_v2.4.1.exe.
What we’ve found so far
We’ve checked the V2.4.1 installer using VirusTotal. All 45 security engines that completed the scan reported no detection for the installer. However, some detections were reported for the installed application. Based on our investigation so far, these detections appear to be false positives.
You can review the scan results here:
What we’ve done
Bitdefender’s Malware Research Team has completed its analysis and confirmed that the file is clean. The detection is expected to be removed in the next couple of updates.
Microsoft has also reviewed our submission and confirmed that the submitted files do not meet its criteria for malware or potentially unwanted applications. The detection has been removed.
Temporary Solutions
Some users may encounter security warnings when installing or running Snapmaker Orca windows_installer_v2.4.1.exe, while others may not. If you encounter a warning, first make sure you downloaded Snapmaker Orca from the Snapmaker website, the official Snapmaker Orca GitHub repository, or through the in-app update prompt. Then follow the steps below.
Before proceeding, verify that the installer’s digital signature is valid.
Option 1: Restore the installed application if it has been quarantined
If your security software flags or quarantines the installed application, you may be able to restore or allow it:
Only restore or allow the file if you’ve verified that it is the official Snapmaker Orca application and confirmed its digital signature is valid. If you’re unsure about the file’s authenticity or the warning persists, do not proceed.
Option 2: Use the portable version temporarily
If you prefer not to restore or allow the installed application, you can consider using the windows_v2.4.1_portable.zip as a temporary alternative.
Download page:https://www.snapmaker.com/snapmaker-orca
We’ll continue monitoring the situation and share further updates if needed. Thanks for your patience.
