My computer prompted me to update the Luban in Software and after I did it crashes every time I try to export G code
hi, can you provide more details like your operating system, some screenshot videos if possible~
I am on Macintosh desktop. After the update I can open up STL make some changes when I click send to workspace the screen goes blank.
Press the Windows logo key and R key at the same time,
Type %appdata% in the search box and enter
Open the âsnapmaker-lubanâ folder and delete the âmachine.jsonâ file
For macOS:
Click on Go > Go to Folder.
Copy and paste the following path to the pop-up window.
~/Library/Application Support/
Locate the folder snapmaker-luban and delete the file âmachine.jsonâ
Also, whatâs your firmware version?
I donât have a Windows key Iâm on a Macintosh
Oh, then a special case. I suggest you email our technical support for help. Just mail to support@snapmaker.com.
I followed these directions and I still have the same issue - the 3D print workspace just goes blank screen.
So if I am in the 3d module, I generate a g-code, then I hit âexport to workspaceâ, it looks like it will work, shows the connection screen, then just blank screen. Does the same in the âshow in browserâ version.
I just downloaded Version 4.3.0.
HELP PLEASE!
I updated the Snapmaker Firmware. That did the trick.
