U1 support for PVA
What are parameters for PVA on U1?
PLA Printing Guide https://wiki.snapmaker.com/en/snapmaker_artisan/troubleshooting/pva_tpu_breakaway_support needs updating for U1.
There is a profile for PVA in Snapmaker Orca already, if I recall correctly. I haven’t had the occasion to try it yet though.
I’ve used PVA on the U1, using the default profile. LOTS of stringing. I haven’t played with the settings to try to minimize it. Other than that, it works fine.
I’d guess you know it’d need to be kept very dry while printing. Wonder if retraction needs tweaking. :thinking:
Yes, I bought a Polymaker dryer/box for it. It is the dead of winter here in the NE, and the temperature has been below freezing for weeks, so the air is very dry, too. This is actually the first time I’ve used PVA. Except for the stringing, it works well. I’m going to use the PVA just for support interfaces, and either PLA or PETG for the supports themselves.
I did my first print using PVA in my U1 last night and it worked a treat. I printed from the polymaker drybox (lowest temp) with the generic PVA profile modified with speed slowed right down to 1mm3 and fan to 10% using the Siddament PVA. Unsure about other brands performance though this stuff curls like crazy if printed too fast or with too much part cooling fan. PVA dried for ~24h @50c prior in dehydrator, zero stringing.
Do you regularly print with PVA?
I would be very interested to hear about your experiences.
I’ve tried many times, but it seems that Snapmaker printers don’t handle PVA cleanly. I bought the J1S a year ago and have never gotten clean results.
I just got the U1.
It seems to be difficult.
My prints are quite clean at 230-250 degrees, especially with a “Maximum Volumetric Speed” of around 1mm³/s, which obviously results in a very slow speed.
It’s embarrassing that my old little Anycubic Kobra 2 Pro prints extremely cleanly and with sharp contours even with standard PLA settings and at full speed!!!
Question: Is there a proven set of parameters for the U1 that really gives a clean, sharp-contoured print?
I can’t help with PVA specifically but I do think that it would help greatly if you could provide some images of the failure you are experiencing with PVA.
Being limited to 1mm/s sounds like there are other problems than the filament. Did you try the filament on different toolheads?
With the U1, PVA is in most cases not needed anyway. Most people use PETG as a support interface nowadays.
I print PETG interface at 5mm/s with 2 layers and it works absolutely perfectly.
