U1: Blob of Death
Thought I’d just post a bit about how things have gone so far and where I’m heading next. I was looking for a printer suited for getting into the hobby and found the U1. Tried a few things, printed some stuff, and was pretty happy with the first results:
Messing with settings, sometimes better quality, sometimes wasted prints — the usual stuff. Didn’t think too much of it when adhesion wasn’t quite right on the first try. Changed the settings again, seemed to work. Well, it didn’t. First tried to remove enough of it, then got the print head out of the printer, and that actually went fine. Here’s the unsightly “blob of death”:
The problem, which you can maybe see better in the 2nd photo, is that the filament was also right next to the print head, basically wrapped around it from one side:
Alright, so I watched a few tutorials and tried to remove enough to at least get to the nozzle, or rather the screws holding it in place. That worked.
So far so good. As you can see from the broken file, the PLA from Snapmaker is pretty hard. I also underestimated the angle a bit. At least heating up should work a little better now… or so I thought. Didn’t really help much. And again underestimated how hard the PLA was. Result:
That’s the blob… still with the nozzle trapped inside. Well, that’s that component sorted. The trickier part is actually the two cables. I do happen to have a matching nozzle, it came with the spare parts. But unfortunately I couldn’t find the matching cables.
Here the spare nozzle and the broken but removed one side by side. Note the missing cables on the spare:
Something I didn’t know before: the 3D printer won’t start without a print head. Fortunately I’d ordered 2mm nozzles back then as well and installed one of those now. So the printer works for the time being with 3 heads (careful not to use the different size together — it doesn’t have PLA either). I’ll probably treat myself to 4 slightly larger spare heads for Christmas… and maybe extra cables, if they even exist.
That’s all from me for now, my first post. If I find the time, I’ll keep documenting progress and setbacks here. So far pretty happy with the printer.
Blob of Death is never fun and the cables on the U1 heads are soooooo fine :fearful:
The good news you can buy the cables as separates as I have some here, I can give you a link for UK/Euro if it helps? I’m not sure if they are available via SM stores as we don’t have one in the UK as of yet
Also I’m not sure about the official FW, but if you run the PaXX version you can disable toolheads so as to keep using the printer
Thank you very much for sharing with us.
Here will be a U1 Beta firmware testing for Blob Detection:
If you’re interested, you can join the Beta Testing here to preview the time schedule:
U1 Blob Detection Best Test Invitation
Here are more details about Blob Detection:
The Beta firmware won’t be ready until November 6.
How Blob Detection works:
Hotend Blob Detection identifies potential hotend blobs by analyzing the visual characteristics of the material near the Toolhead. It uses image analysis and a deep learning-based object detection model to determine whether a hotend blob is present.
Three sensitivity levels are available: High, Medium, and Low.
  • High sensitivity: Detects a wider range of potential hotend blob scenarios, but has a higher false positive rate.
  • Low sensitivity: Detects fewer potential hotend blob scenarios, but has a lower false positive rate.
  • Medium sensitivity: Offers a balance between the detection rate and false positive rate.
Medium sensitivity is recommended for general use.
Vision-Based Hotend Blob Detection.pdf (1.9 MB)
Hotend Blob Detection Beta Test Feedback Form
The wires are attached to the thermistor and heater. Replacements are available:
Imdinnogo Ceramic Heater and Thermistor Kit for Snapmaker U1: 24V 48W Heating Cartridge 300°C Temperature Sensor Replacement to Extruder Hotend Fast Heat 3D Printer Accessories Amazon.com: Imdinnogo Ceramic Heater and Thermistor Kit for Snapmaker U1: 24V 48W Heating Cartridge 300°C Temperature Sensor Replacement to Extruder Hotend Fast Heat 3D Printer Accessories : Industrial & Scientific
Next time, try heating up the hotend to extrusion temp and remove the blob while the material is softened. If the hotend won’t heat up because the wires are damaged, try softening the blob with a heat gun or soldering iron.
