Touch Screen Not Responsive
#1
Hi @parachvte,
I have a few bugs I’d like to report on latest firmware and 2.3.1
My touch screen is not responsive at all.
#2
Try turn off the machine, then turn it on again.
#3
Hi. Bug reports should really go here:
#4
I noticed a similar post by Tone. Since you are doing CNC, I can only comment the following:
It seems that there are certain conditions where the touchscreen display gets stuck and using the computer as an input takes the touchscreen into these stuck conditions.
Regards
Waldo
#5
Hi @PrototypeNow,
Did this happen since the first time you use the printer? If so, please fill in the warranty request at https://www.snapmaker.com/repair. If not, do you remember what you did before this happened?
Look forward to your reply. Thank you!
Best regards,
Rainie
#6
Hi Rainie,
Yes, this has been a problem from first start. I’ve tried both USB into laptop and USB thumbstick. The only way I can control the axis is through Snapmakerjs.
Please help! I’ve only had problems with my machine. I’ve updated the firmware and Snapmakerjs to latest and still have issues. I really love the machine and I hope that I can use it. Thanks for your help.
#7
Hi @PrototypeNow,
Thank you for your video. We just noticed that you also reported another 2 bugs for the CNC function. We would like to have a videocall with you and sort things out.
My skype username is Rainie Zou. Please send me a message when you are ready. If possible, we would like to have the videocall in an hour. Sorry for all the inconvenience.
Best regards,
Rainie
#8
Hi Rainie
I have the exact same issue as PrototypeNow. The Touchscreen does not respond and I can`t update the firmware via USB Stick. Some days ago I was able to fix the touchscreen issue with a firmwareupdate but now nothing is working. The only thing I am able to do is using the snapmaker with snapmakerjs.
Pleas let other customers know if you were able to solve a problem. A conference call isn`t really doing us a favor. Thanks in advance, I love your machine!!!
Cheers Kris
