I’m trying to print a multi-part multi-material object with a main body in PETG (black) and some gaskets in TPU (white).
I added a third part for support that should be printed in PLA (red). This part is set as ‘support enforcer’.
The first image shows the three part components, the enforcer shows as clear blue.
I can’t understand why the support is not sliced where the enforcer is, leaving the top part printed mid air.
Any clues of what am I doing wrong??
(Tried to upload the 3mf file but I’m not allowed to include attachments)
Without details of the slicer parameters in the .3mf, it’s hard to say and would only be a guess (I can’t think of anything). Might even be a slicer bug – what version are you on?
I don’t think we can upload .3mf files to the forum, they’re probably too big and may be an unapproved file type. You’ll need to put it on Dropbox, Onedrive, Google Drive etc (or some file sharing site) and share a link.
You can upload a .3mf if you .zip it
Have you tried slicing it, then using the bar on the right to go down layer by layer to see if that shows anything?
I tried before to upload a ZIP with the 3mf but since I was a new member here I couldn’t upload attachments with the original post. Now it seems I can, so here it is.
Going layer by layer I see the top part of the white TPU gasket starts printing completely in the air at layer 45.
I’m wondering if the problem is that support is supposed to lay on top of a curved base instead of a flat one (the lower part of the white gasket).
3mf File.zip (37.1 KB)
Now I tried enabling ON BUILD PLATE ONLY and TREE(MANUAL) and the result is again to print the white TPU part mid air at layer 45.
It creates a lot of tree structures that seem to make sure the black PETG part is properly supported leaving the white TPU section with no support at all.
This makes me believe the problem is NOT THE CURVED BASE I mentioned before, since in this case support is coming from baseplate and still wrong.
I downloaded and had a look - its strange no matter how I try it will not support the top tpu, my only thought is maybe the gap is to small/too close to the buildplate for the slicer to build the support in?
How ever if I turn the test piece on its side I can manually paint support in between and Ocraslicer then does what we want it to
I’ve attached the file back again with the above done so you can take a peek - its done roughly just to show concept.
Test.3mf.zip (29.2 KB)
I don’t think the problem is the gap being too close because in the previous version I sent (disabling the ON BUILD PLATE ONLY and using NORMAL(MANUAL) support type) Orca creates a small support about 1/3 of the width of the enforcer.
It’s like Orca makes sure the PETG part is supported and not taking care at all of the TPU part.
Part orientation was chosen so I get the buildplate pattern in the face that’s visible once assembled
The minimum gap in the TPU is 3.5mm, that’s a big enough gap for supports.
Well I tried, good luck sorting it
If you are using SnOrca (you’ve not said which version), try vanilla Orca instead and see what that does.
I always use V.Orca, I think its the model not the supports persay, tinkering with the support settings /may/ fix it as I think its the gap and the angles for getting support in there which is stopping it, as its quite happy when I turned the model 90 degrees, but the OP needs it flat so thats out.
I found a workaround.
I changed the support angle to 45 degrees and I get a complete support now.
It IS strange, but I think it’ll work now, so I’ll give it try.
Thanks you guys for your time and hep!!! I do appreciate that.
BTW: I’m using latest SnOrca V2.4.0
Might be worth reporting as a bug. There are beta versions of SnOrca above 2.4.0.
How do you report it as a bug?
I don’t think its a bug, as I suspected its the tight space and the angle required to get support in there - thats why it was building it on part of it, not the whole
As I said I tried in V.Orca & the OP has used SnOrca, its the default settings/limitations
Glad its sorted
