Hello again,
I’m facing some weird pulsating / stuttering extrusion in the near of skins. I tried to eliminate them using all circular surfaces, but that’s not the problem.
You can hear it in the Video I uploaded and see the results on this picture. I also added the gcode.
Please help!
Lager_Rolle_Custom_cooling_mod_regular_2021-02-06_19_48.gcode.zip (425.5 KB)
Did that happen before you did the cooling mod?
Slynold
February 7, 2021, 12:06pm
3
I dont know. I think ist has not to do with it
Honestly it could just be in the model itself, if it was generated at a lower quality with bigger polygons
i have it happen now and then and usually thats what i find
trying to preview it on simplify3d i think i do see this
its hard to tell at this size and i cant really scale it to look further.
Yeah, you have been right. It’s the model -
I see ghosts where there aren’t any.
It was a bit weird because in the middle the problem was gone, and at the top layers it happened again.
Now with a stl exported in ‘fine’ mode, the print flow is okay, no stuttering and pulsating.
Thanks moose!
sometimes it’s that easy
