# Starting to think this is a $1700 paperweight
**URL:** <https://forum.snapmaker.com/t/starting-to-think-this-is-a-1700-paperweight/16924>\
**Created:** [March 14, 2021, 12:51am UTC](https://forum.snapmaker.com/t/starting-to-think-this-is-a-1700-paperweight/16924 "2021-03-14T00:51:46Z")\
**Showing post:** 21
**Post date:** [March 20, 2021, 10:22am UTC](https://forum.snapmaker.com/t/starting-to-think-this-is-a-1700-paperweight/16924/21 "2021-03-20T10:22:56Z")
Maybe this helps:
> [@Why is Laser Burning not finishing paths](https://forum.snapmaker.com/t/why-is-laser-burning-not-finishing-paths/16166/5):
> Now I know what ablate means and how CO2 lasers on youtube don’t create char marks like our diode lasers. Kalmdown, If you are using the 1600mw laser like I do, on cardstock, I would be using 400mm/min and 100% power. Yours looks like just plain thin paper, which might work with even faster speed. Did you run a test grid on it? That will let you know what is a good speed/power ratio. I always try to go 100% and as fast as possible if the results are good. As you can see from my te…
> **[The Definitive Guide to Laser Engraving and Cutting with the 200mW and 1600mW...](https://support.snapmaker.com/hc/en-us/articles/360019025954-The-Definitive-Guide-to-Laser-Engraving-and-Cutting-with-the-Snapmaker)**
> Your Snapmaker lets you turn your ideas into reality. You can engrave on dozens of materials like paper, plywood, MDF, hardwood, leather, fabric, sticker, and even food like cookie! Keep reading to...
_[View the full topic](https://forum.snapmaker.com/t/starting-to-think-this-is-a-1700-paperweight/16924)._
