When I take a .3mf for ASA to print on the Snapmaker U1 using a material like ASA, along with the official U1 top cover, the Gcode that Snorca is generating is telling the exhaust fan to come on at the end of the print – forever. How do I prevent this behavior? Normal behavior for engineering materials that require filtration is that after the job finishes, the re-circulation fan is supposed to run for 10 minutes after the job completes, and then shut off. In my case, the recirc fan runs – but the exhaust fan is set to run indefinitely after. The Gcode that Snorca is creating for this specifically is “M106 P3 S178” after PRINT_END.
There are a few issues on upstream Orca regarding this - for example at M106 P3 S178 after PRINT_END · Issue #8572 · OrcaSlicer/OrcaSlicer · GitHub
My question is how to best work around this for each of my ASA or ABS print jobs without manually commenting these two lines out in the gcode?
Thanks
