Snapmakerjs v2.5.3 Beta Testing
#1
This is the beta version of Snapmakerjs v2.5.3, please check it out and any feedback is appreciated!
Changelog
  • New Features:
    • Added the ability to load multiple models in CNC G-code Generator
    • Added model operations for laser and CNC
      • “Arrange all models” to re-arrange models (images) so that they don’t overlap each other
      • “Send to Back” to send the selected model to the bottom layer and “Send to Front” to send the selected model to the first layer
      • “Delete” to delete the selected model
      • “Anchor” to align an anchor of model to the work origin
    • Added an option to toggle between automatic preview and manual preview. Turn off automatic preview can reduce calculations and memory usage when generating G-code from big images.
    • Added parameter “invert” for laser B&W and Greyscale modes, invert black and white pixels of image
    • Added the ability to modify 3 dimensions of your workspace, well you know, Snapmaker 2 have 3 models with different sizes
  • Bugfixes
    • Fixed the issue that Workspace unable to drag to upload G-code file
    • Fixed some other small issues
  • Removed Linux 32-bit version, Linux 32-bit versions are not longer supported
Downloads
Windows 64-bit
https://s3-us-west-2.amazonaws.com/snapmaker.com/download/snapmakerjs-beta/snapmakerjs-2.5.3-beta.1-win-x64.exe
Windows 32-bit
https://s3-us-west-2.amazonaws.com/snapmaker.com/download/snapmakerjs-beta/snapmakerjs-2.5.3-beta.1-win-ia32.exe
macOS
https://s3-us-west-2.amazonaws.com/snapmaker.com/download/snapmakerjs-beta/snapmakerjs-2.5.3-beta.1-mac-x64.dmg
Linux 64-bit
https://s3-us-west-2.amazonaws.com/snapmaker.com/download/snapmakerjs-beta/snapmakerjs-2.5.3-beta.1-linux-amd64.deb
https://s3-us-west-2.amazonaws.com/snapmaker.com/download/snapmakerjs-beta/snapmakerjs-2.5.3-beta.1-linux-x64.tar.gz
Downloaded a model from Thinkverse. it generates but not loading
#2
I load JPG in to program. Make laser multipas. In generated file was dot from each begin laser cuting.
#3
Hi @Michal
Since the tool head moved to top left corner of your image and only engraved a dot, which means G-code for the JPG image didn’t generated correctly. Pls try to modify your parameters (like lower your “White Clip” or something) to see the G-code can be generated correctly. Or you can always upload your image in this thread and I’ll figure out how the issue comes out.
#4
#5
Now I tested 3D printer on this software
  1. After stop from software - head and bead still heat , not cool down. No button to OFF them
  2. in time print - filament move back too much - leve in printed element holes in places when begin printed element. (PLA)
  3. In time waiting for heat bead filament moves back - have problem with begin print - filament out of head
  4. setings for PLA normal, best not working well. Printed line not glued between them, probably not a lot of filament going out. Print with much older FW and SW have better quality
  5. ADD option to remove all filament from the head use one button - remove at lover temperature to remove all dust and partucles from nozle (automated or hand made)
  6. Still I cant stop/breake print from pilot in time print from PC
  7. 2 times linear module overide end switch but not see them. Only hear them.
  8. FW 2.8. In time Power ON 3 D printer - hear click in 3D head. Probably motor moves on cold head. If filament was inside then can cut them or destroy gear.
#6
Thanks for your image.
Due to the lack of SVG percentage parsing, the extra dot appears there. We’ll fix that before formal release.
