Snapmaker power consumption
#1
Hey guys does anyone know what the power consumption of the Snapmaker with the 3D printing module on is?
As in kWhs as I couldn’t find anything about it in the manuals or on the box besides the normal voltages etc.
#2
It is around 110 KWh when the printing module is working.
There is an output parameter on the power adapter’s label,
That is the maximum output value.
Hope this can help you. :slight_smile:
#3
24V DC x 5A x 1hr = 120Wh
120/1000 = 0.12kWh
Thats what the power supply unit is rated, not necessary what 3D printing module is consuming.
I too was hoping to find out about that as I would like to put a UPS for long prints in case any power cut !
average power consumption of a 3D printer is around 50Wh, although this will varies a little from nozzle and bed temp.
#4
My Snapmaker uses around 40 Wh with 210 degrees Nozzle and 60 degrees bed.
#5
Mine uses more or less 60Wh on average for PLA 210’C and Bed 50’C.
