# Snapmaker Luban Downloads and Updates
**URL:** <https://forum.snapmaker.com/t/snapmaker-luban-downloads-and-updates/4949>\
**Created:** [January 16, 2020, 8:26am UTC](https://forum.snapmaker.com/t/snapmaker-luban-downloads-and-updates/4949 "2020-01-16T08:26:50Z")\
**Showing post:** 37
**Author:** ![parachvte](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.snapmaker.com/parachvte/32/2015_2.png) [@parachvte](https://forum.snapmaker.com/u/parachvte)\
**Post date:** [June 27, 2023, 11:09am UTC](https://forum.snapmaker.com/t/snapmaker-luban-downloads-and-updates/4949/37 "2023-06-27T11:09:26Z")
June 26, 2023, v4.8.1
## System Requirements
- macOS \>= 11, for legacy macOS 10 versions (Catalina, Mojave, High Sierra), please upgrade to at least macOS 11
- Windows x64
- Linux 64 bits distros
## What’s Changed
## Improvements
- Added SM2.0 Quick Swap Kit detection
- Added J1s machine and adjusted parameters for J1/J1s
- Added Quick clear mesh painting in object list
- Added Dual material interlock parameter
- Optimized mesh painting slicing speed & interaction
## Bug Fixes
- Fixed the issue where default presets could not be selected for certain material types.
- Fixed the issue where mesh painting slicing results were incorrect when the model was assigned as a right extruder.
- Fixed the issue with some initial layer parameters being in the wrong directory.
- Fixed the issue with abnormal saving of certain print configuration parameters.
- Fixed the problem of some models failing to slice.
- Fixed the issue where objects could not be selected and deleted in Laser and CNC modes.
- Fixed the problem of Prime Tower not being automatically generated in certain cases.
- Fixed the software crash issue caused by using the pen tool.
- Fixed the issue where coloring STL files was not saved in the project file.
- Fixed the issue where 3D printing slicing would generate extra skins.
- Fixed the problem of J1 Console not being available.
- Fixed the issue of Laser and CNC toolpaths getting stuck.
- Fixed the issue where 3D Gizmos would disappear after use.
- Fixed the problem of confusing material type content.
- Fixed the issue where Laser toolpaths could not be generated on Linux systems.
**Full Changelog** : [v4.8.1](https://github.com/Snapmaker/Luban/releases/tag/v4.8.1)
## Download links
We provide Snapmaker Luban for different platforms:
- macOS x64/ARM64
- Windows x64
- Linux
Please refer to our [Github releases page](https://github.com/Snapmaker/Luban/releases/tag/v4.8.1) to download.
### Feedbacks
For the full user manual for Snapmaker Luban 4.0 and later, please checkout [Snapmaker Luban 4.0 User Manual](https://support.snapmaker.com/hc/en-us/articles/4406229926935).
- File a [support ticket](https://snapmaker.formcrafts.com/support-ticket)
- Create an issue on [Snapmaker/Luban](https://github.com/Snapmaker/Luban)
- Email to [support@snapmaker.com](mailto:support@snapmaker.com)
_[View the full topic](https://forum.snapmaker.com/t/snapmaker-luban-downloads-and-updates/4949)._
