# Snapmaker Artisan Rotary not working with Lightburn
**URL:** <https://forum.snapmaker.com/t/snapmaker-artisan-rotary-not-working-with-lightburn/35798>\
**Category:** Artisan (3-in-1)\
**Created:** [May 7, 2024, 4:15pm UTC](https://forum.snapmaker.com/t/snapmaker-artisan-rotary-not-working-with-lightburn/35798 "2024-05-07T16:15:16Z")\
**Showing post:** 2
**Post date:** [May 7, 2024, 6:36pm UTC](https://forum.snapmaker.com/t/snapmaker-artisan-rotary-not-working-with-lightburn/35798/2 "2024-05-07T18:36:12Z")
Not sure if you did some searching:
> [@Lightburn + Rotary Guide](https://forum.snapmaker.com/t/lightburn-rotary-guide/28542):
> This is going to be a quick guide on the settings/required modifications to use the rotary module with Lightburn. I am sorry, but it will require following the beginning of my full lightburn control guide. Mainly flashing the custom firmware (as of writing, make sure you’re on the latest 1.14.3 before loading the custom firmware and do NOT turn the machine off until it’s done). Follow along until the GCode header/footer section, for the rotary you only need M3 S0 in…
> [@Using Artisan with LightBurn](https://forum.snapmaker.com/t/using-artisan-with-lightburn/34513):
> Dear makers, Good day to all. smile We’ve recently updated the Wiki on Using Artisan with LightBurn. You can check out the instructions below. Hope they are helpful to you! And don’t forget to comment below if you have any feedback or suggestion hugs ! [Using Artisan with LightBurn](https://wiki.snapmaker.com/en/general/manual/use_ray_with_lightburn_guide)[Adjusting the laser height using LightBurn](https://wiki.snapmaker.com/general/manual/adjust_laser_height_using_lightburn)[Setting the work origin using LightBurn](https://wiki.snapmaker.com/general/manual/set_xy_work_origin_using_lightburn)
_[View the full topic](https://forum.snapmaker.com/t/snapmaker-artisan-rotary-not-working-with-lightburn/35798)._
