Snapmaker 2.0 A350 Enclosure Spool Reversal Spacer
My A350 enclosure is sitting too close to the back wall, so I cannot mount the spool holder as intended, facing backwards.
So I designed this spacer to fit into the panel cutout which allows me to mount the spool holder facing forward, like when you don’t use an enclosure.
https://www.thingiverse.com/thing:4641446
PS: I am a new user to Thingiverse, it might take 24 hours that my first design becomes visible.
Question: this print is in the high quality settings. Is there a way to make the top surface smoother?
turn ironing on.
(and another line to get to 20 characters)
Unfortunately Luban doesn’t have an option to iron.
PS: I found that the link to Thingyverse was wrong, here’s the correct one: https://www.thingiverse.com/thing:4641446
Luban is limited, if you want good prints you will need to move on to cura or simplify 3d or some other slicer that is more complete.
