I have a snapmaker snapdryer, it is coming up with a fault code 001 which indicates the fan is at fault. I need some help diagnoising the fan, as I’m unsure if it has a pwm ouput to the control board or a stall run signal to the control board, it doesn’t on investigation have a pwm output, does this mean the fan is faulty
in my case it was faulty control board, if it still under warranty just contact support
