SnapCon, SnapMaker U1 Fleet Management
Long story short, I run a farm of 25 Snapmaker U1 printers, and I got tired of not having a decent way to see and manage all of them from one place.
So I built SnapCon. (ezeitoun/SnapCon: SnapMaker U1 Fleet Management App)
It’s a local dashboard that connects directly to your printers over your own network. No cloud account, no subscription, and no printer data being sent somewhere it doesn’t need to go.
It originally started as a personal tool, and an early version used some groundwork from Danny Gambill’s U1Hub project. Since then, it has grown into something very different, with its own architecture, direction, and a much larger feature set.
A few of the main things it does:
  • Manage your whole fleet from one dashboard
  • Switch between card view, compact view, camera view, and list view
  • Track filament and color separately for all four U1 toolheads
  • Pause, resume, cancel, and exclude objects during a print
  • Heat multiple beds with staggered starts so you don’t overload a circuit
  • Track maintenance schedules and warranty information
  • Send print notifications through Telegram or ntfy
  • Add optional logins and user roles
  • Use secure remote access through Cloudflare Tunnel without port forwarding
The remote access is only a tunnel to your own installation. Your printer data is not stored on or relayed through a server that I operate.
SnapCon is built around the Snapmaker U1 first, because that is what I actually own and use every day. That is still the main focus.
That said, enough people asked about mixed farms that I also added support for FlashForge, Creality, and generic Klipper/Moonraker printers. Those connectors are more of a courtesy addition than the core of the project, but they work and continue to improve.
It’s free, open source, and can run either as a standalone app with no Node.js installation required, or through Docker if you want it running all the time.
You can grab a build from the Releases page, point it at your printers, and usually be up and running within a few minutes.
I’m still actively working on it, so feedback is very welcome. If something is broken, confusing, or missing, let me know.
Do you think this is useful even for a “farm” of just one printer? Looks like it might be…
25!
Thanks for sharing your software
Thanks for sharing!
Have you considered submitting the project for Snapmaker Innovation Fund?
Yes, I did it a week or two ago. Thanks!
