SliceGate — preflight printability checker for multi-tool 3MF projects
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
ForgeFilament
Project name
SliceGate — Preflight Printability Checker
Project URL
Project cover
Project Category
Software
Project Summary
SliceGate is a preflight checker that catches the print-killing defects a slicer either hides or reports too late — before a multi-tool job wastes hours and several materials discovering them.
It grew out of real failures in my own shop. Bambu Studio’s CLI treats a vertical gap between stacked bodies as fatal — “Object can’t be printed for empty layer between X and Y”, exit code 156 — and one of my models had a 0.36 mm gap between two body sections (pelvis top at 16.6 mm, ribcage bottom at 17.58 mm) that cost a full debugging cycle. A prop whose tip dipped to z = −3.95 mm, below the build plate, killed another slice outright. The opposite failure is worse: the slicer silently repairs broken meshes. In a control test, an open, non-manifold box sliced with identical time and filament to the closed cube, so a “successful slice” certifies nothing about geometry — and before this gate existed, one of my products shipped with inverted cap geometry reading −463.63 mm³ of raw signed volume under a claimed PASS.
SliceGate therefore runs two layers before any print or deliverable ships:
  1. Mesh gate (my own code): per-component checks computed from the raw face array — boundary or odd-multiplicity edges (true holes and non-manifold junctions), winding imbalance (the signature of inverted or corrupted geometry), and raw signed volume ≤ 0 for every part, so an inverted or empty body can never slip through. Duplicate-geometry residue is counted and printed on every verdict, never hidden — and the verdict also prints the gate’s known blind spots (thin walls, floating components, and color identity belong to other checks), because a checker that hides its limits is how bad parts ship.
  2. Slice gate: a headless slicer run that catches the slicer’s own fatals — vertical-gap empty layers (exit code 156) and parts outside the build volume (exit code 206) — and returns honest time and filament estimates.
The gates carry a regression suite of known fixtures (a clean cube; open, inverted, partially inverted, and vertically gapped parts — re-run on 2026-11-02, every synthetic fixture receives the correct verdict; three real-world fixtures in the same suite pass the gate but currently miss stricter residue expectations recorded for them, and the suite reports that openly instead of rounding it up to a pass) and have been the standing pre-slice discipline for every deliverable in my shop since October 25, 2026 — including 111 designs and 164 plates slice-verified in a single audit week (October 31 – November 1, 2026), and multi-body color projects like a 16-part, 10-color relief coaster where one bad body would have burned a 5 h 24 min print and four-plus materials of purge before anyone noticed.
The Phase 2 project: package SliceGate as a standalone preflight tool for multi-tool 3MF projects — point it at a project file and get a per-body verdict covering geometry health, plate contact (nothing below z = 0), vertical continuity across the full layer stack, and a pe
Open Source Status
Closed Source
Please specify the open source license used by this project
N/A — closed source at submission; the checker is internal shop tooling today, and packaging it for public release is the Phase 2 work proposed in this entry.
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
N/A — original in-house tooling, conceived and built by me after the failures described above. A headless slicer CLI and open-source mesh libraries are used as instruments/dependencies inside the second layer; the checks, verdict logic, and regression suite are my own.
Is it a paid project?
No
Hi, thank you very much for sharing this project with us.
I think the Project Summary part has been cut off due to text limit.
Would you mind completing it in the comments?:grinning_face:
Since the project URL points to an on-demand 3D printing service, would you happen to have a demo or installer (.exe) that the judging team could use to test SliceGate?
Best regards.
