Side-by-side installation of snapmaker Orca
Is it possible to have two or more installments of Snorca on the same computer?
Since it creates its folders with a fixed name in the user (sub)folders, you might have a clash if you are testing a beta version along your production release. I thought that the portable version would keep its folders to its own, but this doesn’t seem to be the case.
I am doing that from time to time. I am running Snorca on a Mac Mini M4.
In that case I don’t drag the app file into the regular apps folder, but into a different one.
regards
Manfred
I found the proper way:
(Snapmaker) Orca has a lot of command line functions and startup parameters.
Amongst them is the parameter --datadir, followed by de name of the folder.
I used the portable version and copied into a folder.
I created a shortcut on my desktop and added the parameter --datadir D:\MyFolder.
Then I started the exe by its shortcut for the first time
The installed setting files now reside in the given folder and not in the usual one.
This one has it’s own directories:
You can do that with snapmaker orcaslicer.
Download the .zip portable version of a build, unzip into its own folder, and it can be anywhere you want.
In that folder, create a new “Run Snapmaker Orca.txt” file, and paste the following content in. File name can be anything you want.
@echo off
REM Standalone portable launcher for Snapmaker Orca. No PowerShell, no dependency on any
REM other file - drop this next to snapmaker-orca.exe and double-click it.
REM
REM Config is written to .\Snapmaker_Orca-data beside the exe, so the folder is entirely
REM self-contained: nothing goes to %APPDATA%, and deleting the folder removes every trace.
REM
REM NOTE the launcher is snapmaker-orca.exe - lowercase, hyphenated. Snapmaker_Orca is the
REM .dll and the install-directory name only.
setlocal
set "EXE=%~dp0snapmaker-orca.exe"
set "DATA=%~dp0Snapmaker_Orca-data"
if not exist "%EXE%" (
    echo.
    echo   snapmaker-orca.exe was not found next to this script.
    echo   Expected: "%EXE%"
    echo.
    echo   Keep this file in the same folder as snapmaker-orca.exe.
    echo.
    pause
    exit /b 1
if not exist "%DATA%" mkdir "%DATA%"
start "" "%EXE%" --datadir "%DATA%" %*
endlocal
save, and change Run “Snapmaker Orca.txt” to “Run Snapmaker Orca.cmd”.
Now when you double click this “Run Snapmaker Orca.cmd”, it will launch the snapmaker-orca.exe in the same folder, and put all the settings in “Snapmaker_Orca-data” folder in the same location. Do not run snapmaker-orca.exe any more, otherwise it will use the
%appdata%\Snapmaker_Orca
path, and MAY cause conflicts.
You can also copy this .cmd file to other builds of snapmaker orca.
Thank you for sharing my build.
