I use regular OrcaSlicer with my U1, and the one thing I kept missing was Snapmaker Orca’s print step, so I built it: a free add-on that does the Snapmaker Orca part of printing to the U1. It’s called Set & Send for Snapmaker U1.
When you press Print, a pop-up comes up (much like Snapmaker Orca’s) with:
a preview of the plate, print time and filament used
a toolhead picker for each filament, already matched to what’s loaded in your U1 by material and colour
Auto Leveling, Extrusion Flow Calibration and Time-lapse Camera tick boxes (remembered for next time)
the Top Cover mode: Auto picks it from your filaments using Snapmaker’s own rule, and you can override it per print
Then it sends the print to the U1 and starts it, same as Snapmaker Orca.
It’s unofficial: not made or supported by Snapmaker. It uses the same printer commands Snapmaker Orca sends.
It only talks to your printer on your own network, nothing else.
Tested on Windows with my own U1, and on macOS by another U1 owner (on a Mac, allow printer access by running Check U1 connection once in the Plugins window). Linux hasn’t been tested yet.
It’s free. There’s an optional tip jar on the guide page if it saves you some hassle.
If you try it, I’d love to hear how it goes, especially from Mac and Linux users, and anyone running more than one U1. Bug reports welcome here or through the guide page.
I don’t understand. I’m currently using Orca 2.4.1, and the option to send the print file to the U1, or send and start printing, works just fine without an add-on.
The function I’m truly after is to delay the start of a print, so I can setup a print before going to bed and have it start at say 6am as SWMBO won’t let me run it overnight as too noisy, but I could get away with an early start - is this something feasible for you to look into?
A delay start is an interesting idea… its been mentioned elsewhere.
Not to hijack the thread, you could try to trick the printer with a timed wait or delay, similar to what they do with the Top Cover for the chamber temp. Probably a separate printer profile with the modified start g-code…
I tried one of the U1 print processing plugins while experimenting with 2.5.0. Specifically looking for the options available for the Dynamic Flow Calibration. I can’t be sure that I was using your plugin.
Anyway, I sent the a print while the printer was in use. It didn’t have a notification that the printer was in use, and seemed to succeed. I didn’t check if the file was uploaded, and just didn’t kickoff.
How would this plug-in handle the printer in use scenario?
Yeah it works, but you have limited control over which toolhead is assigned to which colour, and don’t have the ability to toggle things like ABL, Top cover, Light, etc etc. All things you can do with Set and Send
Howdie With Set & Send that shouldn’t happen. Before it sends anything, it checks what the printer is doing:
In the pop-up, the printer shows as Printing with “This printer is printing”, and the Send button is greyed out, so you can’t send to it. If you have more than one U1, you can pick another one from the drop-down at the top.
With the pop-up turned off, OrcaSlicer shows a message saying “The U1 is printing, so nothing was sent”, and nothing goes to the printer.
Since 1.0.8, it also waits if the U1 is loading or unloading filament or calibrating.
What you saw (no warning, the file seemed to upload but never started) sounds like OrcaSlicer’s own upload without Set & Send running, or another addon. The U1 accepts the file while it’s busy but ignores the start. To check it’s Set & Send: you’ll see the “Set & Send” pop-up with the toolheads and print options after you click Upload & Print, and it’s listed in the Plugins window (the small file icon next to File).
For flow calibration, Set & Send has a Flow calibration switch in the pop-up, which turns on the U1’s own flow calibration for that print. Guide: Set & Send – LayerLab
That depends whether Filament Auto Mapping is enabled at the U1. If it is disabled, then there is an exact 1:1 mapping of the filament numbers to the toolheads. Assignment of toolheads is well controlled, either by matching filament type and colour to those that are loaded, or directly under control from the slicer’s G-Code.
All those controls are on the Device panel in SnOrca.
I don’t object to you presenting your mod, but please don’t understate what the user can do using stock facilities.
Haha yes, I understand Snorka can do these things, but this plugin is not made for Snorka, It’s made for Vanilla Orca, which up until recently with Orca Plugins, could not do any of these things.
@ColdCoffee done! Set & Send 1.0.9 (OrcaSlicer 2.5.0 and newer) has Start at a set time. Pick 6:00 am under Start in the pop-up and send it before bed. The print goes to the U1 straight away and waits there with the heaters off. The screen shows it at 0 % with “Starts 6.00 am” at the front of the file name, then it starts by itself. You can cancel it on the screen any time, and your PC can be switched off.
@KCC_703 that’s pretty much your idea: Set & Send puts the wait at the top of the file, so no separate printer profile needed.
