Remote Screen Access's Web Interface is "different" unusable (solved)
After first coffee and then attempting to follow instructions on the
Custom Snapmaker U1 Firmware web page,
Getting to the http printer ip screen succeeded.
I set maintenance to Advanced and rebooting printer.
Instructions tell me to Nav to firmware-config web interface
then go to web section, and enable Remote Screen Access
The graphic on the
Firmware Configuration web page did not appear during my attempt to follow above instructions.
Instead, upon having called up the http url /firmware-config web page, under the left side “Home” the categories are Idle, Tool, Macros, Fans & Outputs, Printer Limits, Thermals, Console, Jobs, and Gcode Preview.
I clicked on the left, Home, Console GCode Preview, Jobs, History, Tune, Configuration, System, and Settings. I found on indication of the necessary “enable remote Screen Access.”
Next I tried putting the machine to root (danger, danger) and tried all the menu picks again, and, no evidence of “Remote Screen Access.”
Surely, I’m barking up the wrong tree or greviously misreading the Remote Screen Access web page. Maybe caffine deficiency is messing me up.
I’ll highly, highly appreciate being pointed in the right direction, and I promise to drink more coffee before trying stuff like this.
Happy Printing !!!
I’m no IT guru, so this may or may not help :slightly_smiling_face: .
When you talk about “Idle, Tool, …” and “Home, Console GCode Preview, …” that’s the Fluidd interface (http://printer-ip), not the firmware configuration page (http://printer-ip/firmware-config).
Since you already enabled “Advanced” on your printer, you should be able to just enter the firmware configuration page by typing http://printer-ip/firmware-config (with printer-ip being your specific IP address, of course) in a browser and there you’ll see the options to enable remote access and others.
Assuming I understood what you’re aiming at.
Have you installed the Paxx custom firmware for the U1? The remote screen is a feature of the Paxx firmware, not the official Snapmaker firmware, and the information pages you have referred are for the Paxx firmware features.
Without Paxx installed, you will just get the Fluidd interface (which is what you are describing).
With Paxx installed, [U1 IP]/screen gets you the remote duplicate control panel, and IIRC it is enabled by default (but you can turn it off in /firmware-config).
Hi @CrazyIvan and @mvall
 Yikes!   I've not installed Paxx,  Gasp!!!  Panic!
I'll get right to it.
Thanks for replying!
Happy Printing !!!
It would be great if you marked the thread as solved (tick the post which gave the most help).
Right - that’ll make a difference! Good luck
