Read-only API access without manual confirmation
I would like to propose a change to the SnapMaker API. I would like to see a “readonly” parameter on the /api/v1/connect API. When set to true, the connection does not require manual confirmation via the touchscreen, but is restricted to querying the status via the /api/v1/status API.
Could you please consider this for a future firmware upgrade? It would make it much easier to write custom monitoring solutions. Thanks!
I asked about this just after getting mine, since I want to monitor it but NOT control it… So far no luck.
