Random HELP - Ask here!
#68
Hi Doug,
Sorry late getting back to you. Using Macbook Pro, High Sierra. I found I can open .stl files from within the program but I can’t double-click on the .stl file to open in Snapmaker3D, it throws an error.
#69
Hi @prodigerati
Alas I have no ideas as you have gone to the dark side with Macs (hahahaha) maybe @Rainie can help
Have a good weekend.
Doug
#70
Why does my printer start printing outside the heated bed?
#71
I assume you are talking about the start of a print; if so this is to start the filament flowing freely before starting on the print bed.
Doug
#72
Hi all, I am wondering if anyone else is having this problem.
I am trying to use the usb and touchscreen to laser engrave. However when I export gcode from snapmakerjs the output is .nc file. When I load it to the usb and use the touchscreen it thinks it is a cnc file and cannot run even though I have the laser module plugged in. I am running 2.2.2 of snapmakerjs and I got my snapmaker about a month ago so should have the latest firmware on it. As an aside the laser engraver works fine when it is connected to my pc, I just don’t want to have to connect it everytime I want to engrave something.
Thanks for helping.
Tony
#73
Do the SnapMaker docs list GCODES that the controller understands?
If not, could someone on the SnapMaker Team list them somewhere on the forum? - Thanks
#74
Hi @tone
All I know so far is that Snapmaker modifies the Marlin system for use. So all the Marlin G-Codes should work.
Snapmaker have an additional command of M1005 to display the installed firmware. Have you seen the Marlin G-Codes
Doug
#75
Nope. Looking now…
adding it to the Wiki now…
#76
@Tone
Soon we will be ‘youngies’ and not newbies any more hahaha get ready to shed the training pants (be prepared to clean up messes though)
Doug
#77
@Rainie, Does the SnapMaker support all the Marlin GCODES?
#78
@Tone
I found this cheat sheet last week RepRap GCode Cheat Sheet However I have not had time to see if it is directly applicable to the Snapmaker configuration, nor have I added it to Snaplinks until it is validated.
Doug
#79
I have the same problem. I loaded a bunch of files and they all said
cnc
cnc
cnc
I choose one and nothing happens. Did you get an answer?
#80
No answer yet, think it is a bug and it still doesn’t work for the latest software
#81
Hi all- question regarding how to adhere pieces you build together. If the item you are building has multiple pieces, what do you use to adhere them? Superglue? Is there a special glue or method for PLA filament?
#82
hi @Jen, i use Loctite Super Glue Gel. I got the info from this video https://www.youtube.com/watch?v=VZWOUpx2UDk
#83
@Jen
I have successfully used superglue on PLA and I have read that the Gorilla Superglue Gel is very good for PLA gluing. I guess this is like what @kelvin8r suggested with the Loctite version
Doug
#84
Thanks @kelvin8r
i will add this video link to Snaplinks.
Keep having fun.
Doug
#85
@doug @kelvin8r Thanks to both of you! I did find some info that the Loctite 401 is awesome to use!
#86
Hey everyone! How can I clean this up?
#87
The little spatula that came with my Snapmaker works wonders for getting almost any filament residue off the print bed. I use a putty knife tom scrape off glue stick.
