Everything worked fine until I installed the enclosure. Now I am unable to load G-code using Wifi. Now I must use the USB. Also enclosure controls do NOT work from Luben 3.13.1. Any suggestions?
Double check that you plugged every cable in the the right port as they are specific to the function…
Yes, I have double and triple checked connections. I can control lights and fan from a touchscreen. When I press the “Load G-code to workspace”, I get a locked and enclosure screen with lights and fan buttons that don’t work.
