Lately, the quality of my prints are starting to deteriorate, and I have not changed much in terms of the configuration or the SM Original device.
See the picture below, I tried to print a RPi case (to setup Octo print), and there are a lot of issues with the consistency.
Any tips on what settings I should be changing? The settings I use to print are below:
Layer Height - 0.2mm
Initial Layer Height - 0.3mm
Initial Layer Line Width - 100%
Wall Thickness - 0.8mm
Top Thickness - 0.8mm
Bottom Thickness - 0.6mm
Infill Density - 8%
Infill Pattern - Grid
Initial Layer Print Speed - 18mm/s
Infill Speed - 60mm/S
Outer Wall Speed - 60mm/S
Inner Wall Speed - 60mm/S
Top/Bottom Speed - 70 mm/S
Travel Speed - 70mm/S
Initial Layer Travel Speed - 30mm/S
Enable Retraction - Yes
Retraction Distance - 6.5mm
Retraction Speed - 25mm/
