Power problems with Snapmaker 2
Hi folks - I have an odd error with my SM2/350f. I have an enclosure, as well as the dual extrusion head. I recently took my 'maker offline to replace the rails, add the quick change kit, and install the stop button. When I reconnected it, when I have the enclosure cable plugged into addon 3 (2 up from power) on the snapmaker cable hub, the heartbeat does not come on nor does the front ‘phone’ boot up. When I disconnect the cable, both functions immediately start.
Has anyone encountered this? Is my power supply (the new one) misbehaving? I have the latest firmware - installed so that I can use the dual extruder - so unless there’s a bug there, I doubt that it’s due to that. Anyone have any thoughts?
Is there any way to purchase a new power hub? It’s currently unusable and a hunk of metal on my desk rn
Does the issue appear if you disconnect the stop switch before starting?
Your dual extruder did already work in the past?-Did you ever printed?
I think this is a firmware issue. I remember a misbehaviour years ago where some specific module updates had to be done.
Maybe only connect one new module at once at startup.
Holy smokes. That worked and allowed me to update the firmware. This has been broken for two years. Thank you very, VERY much for the advice
Glad it helped :wink:
