Out dated everything
every module i recd and the hot bed for the printer do not work… I would like to return the whole thing
Then you probably should.
It would be very strange.
Are you sure you connected everything according to the instructions? Did you talk / write to the support?
i tried everything… unplugging and replugging in different outlets …un installed and re-installed…nothing works…maybe its the little had held thing
If you want to find help here you need a little more detail.
Do the power module and control module have breathing lights?
Does the touchscreen remain black or is there any sign of life?
