I just purchased the 350T with the enclosure and 4th access. All I can say is this was the easiest project I’ve ever been involved with. The instructions were clear and exceedingly easy to follow. The fit and finish is perfect. I’ve already run a spool through it with amazing results. The Snapmaker makes my Series 1 look like a toy. The only problem I’ve found is the large side door opening and closing can be a bit of a challenge because of the weight but I have an easy fix for it and I’ll publish the fix once I print the parts. Well done Team Snapmaker…Now all you have to do is publish a PDF with console commands for Hot end and table heat calibration and filament flow
I just sprayed a small amount of lubricant in the track and that smoothed it out fine.
