new are the dual extruder (13) which this pull request is about. But also mentioned are the rotary module, air purifier, and emergency stop which were on the public roadmap.
I didnât hear about the âtool_setterâ before. Anybody have an idea what thatâs about?
Thatâs the most interesting item on the list. Hereâs an example. I picked a not-inexpensive Mitutoyo, analog variety, for illustration. Itâs essentially an indicator that reads how much youâve pressed down on a button. The magic is that distance between the button and the base is a well-calibrated height.
Digital versions of this can measure the distance of an FDM nozzle to the bed with higher potential accuracy than a contactless sensor, and can directly measure the length of a cutting tool in the milling head. Cheap versions of this tool just sense âfirst conductivityâ to measure height. Better versions use first conductivity as a limit switch and then make a more precise measurement for the actual deflection. Those of you whoâve seen me post elsewhere will have a very clear idea of which one I think SM will ship.
thatâs interesting. I am toying with the idea of creating a spring loaded version of a z-probe which would help especially with the cnc but could also be used with the 3d printer module. But I was going for a simple conductive version, but spring loaded and with a âsafety switchâ controlled from the outside with an esp32 to avoid breaking tools. Especially with v-carve bits and very small drill bits used for pcb milling. For example when thereâs a small piece of plastic or wood stuck on the tip of it.
