Multi-Material Prosthetic Pylon Cover System
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
thomasargo
Project name
Project URL
Project cover
Project Category
Workflow
Project Summary
This is a project I’ve been working on for my father who is a bilateral amputee. I designed covers that go around the pylon section of both of his prosthetic legs, mainly to give that area a fuller and more natural shape especially when wearing pants. I’ve already designed, printed, assembled and tested the first version on his actual prosthetics, so this isn’t really a new idea I’m starting from scratch.
The current version is mostly PETG and it works, but there’s definitely things I want to change now that I’ve actually made and tested it. One problem I ran into was the connector piece that goes around the pylon. It has to flex open enough to actually get around the pylon when putting the cover on, and PETG really isn’t great for that. I actually ended up cracking one of the connectors from the stress of flexing it open.
That’s a big reason I want to start experimenting with multiple materials for the next version. I could keep the main cover rigid, but use TPU or another flexible material in areas that actually need to flex or grip the pylon. There’s other ideas I want to try with it too, but I don’t really know what the best solution is yet. I would rather make different versions and actually test them than say right now exactly what the final design is going to be.
This is where the U1 would be really useful for me. Having independent toolheads would let me keep different materials loaded separately and actually design parts around using them together. I also really like that it doesn’t have to purge a ton of filament every time it switches materials. If I’m making prototype after prototype trying different designs, I don’t want to waste a bunch of material every time I do it.
I currently use a Flashforge AD5X at home and that’s what I made the original covers with. I like the printer, but the U1 would let me do things with this project that I just haven’t been able to do with the current setup. The larger build size would also give me more room to redesign the covers without having to make decisions just based on what fits on my printer.
I don’t want to just take the same model I already made and print it on a U1. I want to use it to keep developing the project, try different material combinations and attachment methods, make new versions, test them on the actual prosthetics and see what fails or what works better. I’ll document that process as I go because I think the failed ideas are part of figuring this out too. The covers I have now work, but I think there’s a lot more I can do with them.
Open Source Status
Open Source
Please specify the open source license used by this project
N/A
Cash Fund or U1 Hardware Sponsorship
Originality
Derivative / Improvement
If based on an existing project — your independent contribution
The original pylon covers were designed and built by me, so this project is an improvement of my own previous work. My contribution for this phase is redesigning the system based on what I learned from the first version, especially the attachment points and the PETG connector that cracked from having to flex around the pylon. I want to experiment with combining rigid and flexible materials, improve how the covers attach and fit, reduce the number of separate parts, and test multiple versions on the actual prosthetics. I’ll be doing the CAD, prototyping, testing and documentation throughout the process.
Is it a paid project?
No
Wanted to add some more pictures of the current version since most of the project summary is about where I want to take the design next.
Once the project reaches a finished and validated state, I plan to make it open source so others can use, modify, and improve the design for their own needs!
I’ll add more updates here as I make changes to the CAD and test different ideas.
Thanks for submitting the project. As “U1 Hardware Sponsorship” is selected in the submission form, I’ll remove the “Cash Fund” tag. Best regards.
My apologies, I accidentally selected the wrong tag. Thank you, I appreciate it!
