Hey guys!
For those of you that aren’t on the discord server, here’s my simple minimalistic candle holder
Here’s the whole album:
I am currently working on creating a lithophane version of the cover part My current design is modular so that you can put new Lithophanes in whenever you want
I’ll share the designs soon
If you want to make your own cover, the Cube dimensions are 59mm x 59mm You can make it as tall as your printer can support, or you can try to make a modular one that can use blocks
Be careful to leave a wide enough hole at the top for the heat to escape though, as otherwise the PLA/filament that you use may melt or deform and that wouldn’t be good
Thanks,
Greg
