I try to change the fill density to another value as preset. (now 15%)
I can see the value - but it is gray.
I cannot change the value to a higher value i.e. 50%.
What should I do?
regards
K.D.
What should I do?
regards
K.D.
Hi. If you are using luban. Look at the settings on the right hand side.
If you are using one of the pre set profiles , then you can not change the settings. You have to add a profile.say pla+ then you can change the settings.
I copied them ALL across except the density infill…
Hi Minto,
thank you for the answer - it works well
Do you know how I can change the type if filling pattern?
There is preset that " rectagle pattern" - I don’t like it.
As I understand is Luban based on CURA - ther you have different fill pattern. I used before the “Line pattern” - gives a better object stability and it’s easier to print.
I cannot find a change posibility. For the support structure there you can set different pattern - why not for filling ?
Is there a possibility to add this feature ?
regards
K.D.
you have to change it in the print speed settings. I usually copy the ‘fast print’ using the button on the bottom left of the pop-up, then save my changes as a ‘new fast print’ mode
