Linux mint 22.3 and snorka issue
I’m having a problem getting Snorka Appimage to work. It will load to the main screen where the login button is and preview of prints but it won’t respond as I can’t click on anything. I also have to kill the process to close it.
Another interesting thing is it didn’t go through any setup wizard.
It was suggested that my CPU is too old as it only supports Opengpl of 3.1. It’s a i5 2320 I have a i7 3770 coming for it.
Anything else I should look at? I tried the newest version as well as 2.3.6 which worked on my other machine but get the same thing.
Hi, Snapmaker Orca V2.4.1 has just been released. Could you please test whether the latest version helps with the current issue?
V2.4.1 | Snapmaker Wiki
The SnOrca appimages don’t work for me either (LM22.3), but I have had some success with the flatpaks (not every release). There has been a suggestion this is because of Wayland and/or Nvidia graphics.
My solution is to use vanilla Orca – that works fine!
Thats the one I tried last night and it does the same . At least the appimage did, Somewhat new to Linux and not totally sure how to install the flatpak version.
I also had the same issue with the original Orca but will try again.
Im using X11 not Wayland and onboard Intel graphics so no Nvidia. Not sure how to manually install and uninstall flatpaks.
It’s easy, and instructions are only a search away, but in summary:
  1. Download the flatpak and move it somewhere suitable (anywhere – I use a folder called “applications”).
  2. In your file manager, navigate into that folder.
  3. Right-click and “open terminal here”
  4. Command: “flatpak install [filename]”
That’s all there is to it. The flatpak gets added to the apps in the usual way.
Comments:
  • If the flatpak command complains you need admin privilege, prefix the command with “sudo” and then you will be asked for your admin password.
  • You don’t need to actually type the filename, just the first few letters then until the correct file is displayed.
Got it figured out. It was my stupidity . I was wondering why I never got a setup wizard. So I got asked by someone to show them a print screen of the terminal when launching and a print screen of the what the program looked like once up . Here is what I got for a printscreen. It was showing the setup wizzard on a seperate monitor (TV) which I wasnt using. So i shut that off in the display options and ran the wizard and now seems to be working.
Thanks
