# Linkage mode noise problem
**URL:** <https://forum.snapmaker.com/t/linkage-mode-noise-problem/20210>\
**Created:** [August 1, 2021, 3:37am UTC](https://forum.snapmaker.com/t/linkage-mode-noise-problem/20210 "2021-08-01T03:37:23Z")\
**Showing post:** 4
**Author:** ![kwi](https://avatars.discourse-cdn.com/v4/letter/k/77aa72/32.png) [@kwi](https://forum.snapmaker.com/u/kwi)\
**Post date:** [August 6, 2021, 4:12am UTC](https://forum.snapmaker.com/t/linkage-mode-noise-problem/20210/4 "2021-08-06T04:12:00Z")
Chosing the right step down depends on the material too - and you can use it in conjuction with
“plunge speed” (how fast the tool drills downwards into the material when it comes from the outside)
and “work speed” (how fast the tool moves when already inside the material)
to find a good middle ground between speed, accuracy, and tool wear&tear.
There is no comprehensive guide yet on which values are suggested in the two rotary module carving
modes (rotary/linkage), but this might help already to get a feel depending on your material:
> **[0. Introduction](https://support.snapmaker.com/hc/en-us/articles/4404739752855-Snapmaker-2-0-CNC-Carving-V1-1-0-)**
> This manual instructs you to use the Snapmaker 2.0 A150, A250, and A350 CNC carver. The three models with different sizes share the same function, so we will demonstrate their use with the A350 mod...
> [@CNC Recommended Parameters](https://forum.snapmaker.com/t/cnc-recommended-parameters/17422):
> Specs of Snapmaker 2.0 CNC motor Operation voltage: 24V Working power usage: 40W - 50W No-load current: ≤ 1.2A Locked-rotor current: 3A Speed: Up to idle 12,000 rpm When you use Carving V-Bit in Relief mode, it is recommended to use the parameters below. Note : You can get more information about woods’ Janka Hardness at: When you use Flat End Mill in Vector mode, it is recommended to use the parameters below. Note 1 : You can get more information about woods’ Janka …
_[View the full topic](https://forum.snapmaker.com/t/linkage-mode-noise-problem/20210)._
