What’s the largest nozzle you can expect to use on an A350? There are things I’d like to print that are big and don’t really care how they look. Like I want to print a cyclonic adapter for my shop vac but just the top is saying 50 hours. Other shop tools like that that just take too long with current nozzle. I don’t care if output looks a little unsightly. Still needs to be strong and functional though.
How big and fast can I go?
-Steve
I believe you can buy 1mm mk8 nozzles? This should increase your print speed assuming same wall thicknesses by approx 2-4x when compared to 0.4mm nozzle (if my maths is right)
I have used up to a 1.0mm nozzle but I have seen up to a 1.2mm nozzle available. Your print speed will be reduced compared to a 0.4mm nozzle because you can only melt filament so fast… You will not be able to use Luban for slicing because I don’t think it has a nozzle diameter setting that can be changed iirc.
I have some issues printing with 1mm nozzle, could you, please, share your parameters?
