# Is automatic level compensation working properly?
**URL:** <https://forum.snapmaker.com/t/is-automatic-level-compensation-working-properly/12386>\
**Created:** [December 7, 2020, 7:42am UTC](https://forum.snapmaker.com/t/is-automatic-level-compensation-working-properly/12386 "2020-12-07T07:42:13Z")\
**Showing post:** 17
**Post date:** [December 9, 2020, 3:48pm UTC](https://forum.snapmaker.com/t/is-automatic-level-compensation-working-properly/12386/17 "2020-12-09T15:48:23Z")
It doesn’t hurt to try.
To do an 11x11 grid you’ll do the following steps. This can be done over wifi as you don’t need a read back.
G1029P11 ; Define 11x11 mesh size
G1029A ; Run auto calibration
After that completes it will leave the nozzle near the center waiting for you to set the height with the calibration card. Use the jogging controls via Luban or via the touchscreen. Don’t move in X or Y, only Z, and do the normal light tension on the card.
Then finish with these commands:
G1029S ; Offset matrix by current Z position
G1029D0 ; Compute interpolations and enable bed leveling
_[View the full topic](https://forum.snapmaker.com/t/is-automatic-level-compensation-working-properly/12386)._
