It does a diagonal line of dots, then moves down 10 cm. and lowers itself on to the bed, until it stalls and says failed.
- powered off
- Checked cables, reseated cables.
It seems to move about the 3 Axis.
Touchscreen doesn’t get to a any other screen then the Initial setup screen.
My router sees it, Luban sees it.
Thought about loading firmware, but I am not able to get to a screen that allows that.
Is there a way to load firmware without doing the Initialization ?
Thank you for any help you can give
Scott Donovan
kb1eea@arrl.net
