I’m the independent developer of MakerSpell, an Android app that combines multi-platform model discovery, local Orca-based slicing and network printer control in one mobile workflow.
I have been testing it with my Snapmaker U1: open a model, prepare and slice it directly on Android, then send the resulting G-code to the printer.
I currently test with a Snapmaker U1, but feedback from other Snapmaker models is welcome. Available features may vary by model and firmware.
MakerSpell is not affiliated with or endorsed by Snapmaker. It is currently in open testing, and compatibility may vary by firmware and configuration. I’m looking for honest, reproducible feedback from other U1 owners.
No worries, and thanks for checking it out! U1 is simply the Snapmaker printer I currently have available for testing—the app is not intended to be limited to U1. I’d also be interested in feedback from owners of other Snapmaker models, especially regarding discovery, monitoring and G-code transfer. Which Snapmaker model do you use?
That’s great to hear, thanks! 2.0 feedback is very valuable since I only have a U1 here for hands-on testing.
Could you share your exact 2.0 model / enclosure / firmware? And if you get a chance to try it, I’m most curious about:
printer discovery over LAN
G-code upload + print start
monitoring / camera if you use it
Anything reproducible with firmware version + request ID helps a lot. Thanks again for jumping in!
If a feature isn’t supported on 2.0, the app should show it as unavailable instead of failing — please tell me if it does the opposite somewhere.
