# How to make different CNC passes (rough / fine)
**URL:** <https://forum.snapmaker.com/t/how-to-make-different-cnc-passes-rough-fine/39996>\
**Tags:** Gcode, Snapmaker\_Luban\
**Created:** [September 5, 2025, 6:25am UTC](https://forum.snapmaker.com/t/how-to-make-different-cnc-passes-rough-fine/39996 "2025-09-05T06:25:33Z")\
**Showing post:** 2
**Post date:** [September 5, 2025, 6:01pm UTC](https://forum.snapmaker.com/t/how-to-make-different-cnc-passes-rough-fine/39996/2 "2025-09-05T18:01:19Z")
Here is a guide about using multi pass with Fusion 360:
> [@Fusion 360 Guide For Multi-Pass 3D Engrave](https://forum.snapmaker.com/t/fusion-360-guide-for-multi-pass-3d-engrave/23143):
> In a bit of a follow up to my [Laser Guide](https://forum.snapmaker.com/t/accurate-repeatable-laser-guide/22779) and [Rotary CNC Guide](https://forum.snapmaker.com/t/multi-pass-rotary-guide/22121), I’ve decided to do a quick 3d relief guide for the snapmaker using Fusion 360. This guide assumes you know some basics of running the CNC, such as being able to jog the machine with the control app, set work origin, and set origins for the axes independently. There will also be some optional G-code changes and sizing done in other programs to achieve a better result. Disclaimer: I am in no way responsible for any possible damage to…
There is a lot around in the forum.
_[View the full topic](https://forum.snapmaker.com/t/how-to-make-different-cnc-passes-rough-fine/39996)._
