I’m having trouble updating each module, the first one updated (laser) but I cant get the other two to update.
When you plug them in, it doesn’t automatically say it wants to update them?
Hi, No it says outdated firmware detected and check website for update before use. I have already updated the firmware for the first module but it gives no option to update the other modules.
Have you already updated the firmware for each module?
I believe that you only need to update them once so far and not for every firmware update.
Before 1.13.1 you never had to update modules individually - just the machine. It didn’t matter which module was plugged in for the update.
Hi the machine says its updated, but when you plug in modules its says update needed
For modules you need to update with the firmware on a usb drive.
For some reason you can’t do it using wifi.
