Goto Position After Layer Print
Hello,
I would like to know if someone can help me with a situation.
I like to do some timelapse movies and i use a mechanical trigger for the camera and i normaly use a 2mm cylinder in a backward position where each layer when printing in that position it triggers the camera…
This… rudimentary solution has a lot of problems… and i would like to know if there is a more simple solution in Luban to do this kind of work?
Was thinking on a goto position after each layer… but done by luban, in a simple option… not editing any stl file or something like that.
Thank you,
I think the easiest way would be to use the Cura timelapse plugin or a similar postprocessor that can inject custom gcode to move to a certain position each layer. That could work with your cylinder that triggers the camera quite nicely.
