Generating G-code fails, snapmaker hooks up during slicing
I have a very simple 3D structure made with Sketchup. When I upload it to Snapmaker.js nothing happens and slicing hooks up at 27.6% cyne_kulie_clipper_5.stl (76.7 KB)
My snapmaker version is 2.5.2
Same problem with 2.7.1
I get the same hang on 2.6.1.
The model is so tiny, I scaled it up by 1000% in all 3 axises. I notice there’s some kind of surface imperfection on the straight part:
If I zoom in on the original, I can see it too, it’s just easier to see on the scaled up version. I don’t see that line on the opposite side. You likely have some surface or mesh disconnects in your source model. There was another thread about model problems, and @moonglum suggested using Sketchup’s solid inspector plugin.
Thank you very much! I did a new model and scaled it bigger. Now everything works :slight_smile:
