Found a bug loading files to print
Its simple doesn’t require much of an explanation if the filename has a % in it, it won’t load, just kinda hangs the loading bar for a min then it goes away and didn’t load.
That is all
Noted. Should be a simple fix and I will forward this to our team.
Hi, I just heard back from our team and this is an issue with the Windows system. Files containing special characters in their file names don’t import well in software. So the current fix is to not use a file name that has special characters and rename it without the special characters.
Of course its windows…damn Microsoft, screwing things up since the 80’s
Thanks for the reply.
