Fluidd Temperature Maximums
It seems to me it would be very useful to have the Thermals panel in the Fluidd interface display the maximum values reached since last reset (particularly the X and Y drivers), otherwise a peak in temperature is only apparent until it exits the duration of the chart display.
Possibly this feature is available elsewhere. Anyone?
I’ve not listed this as a feature request because I have no idea whether this is possible, nor how to go about it.
I misread your message so ignore the above!
I’m sure SM said they are rated to 120c, so I /presume/ there’s some sort of warning/shutdown at that point?
Not that it helps you, but since I did the fan mod and slapped a Noctua over them even it 100c bed and 60c chamber they only got to 65c
Useful to know, and I do intend to upgrade the cooling, but irrelevant to the point. Regardless of application, I’m sure it would be worth recording the peak temperatures – even ancient (pre-digital) weather thermometers do that!
