First layer offset for exposed infill
I’m trying to use snapmaker orca to do an exposed honeycomb infill on the bottom/top layers (a dessicant box), but after slicing, the first layer is offset to the top left, so the exposed honeycomb is a little mangled. This works without issue in regular orca as well as prusa slicer. How do I work around this? Its easy to duplicate: from a blank project add a primitive, then set 0 bottom/top layers, honeycomb infill (though others also have the issue), slice, the look at the first 2 layers. Attached image (on left) demonstrating this, with original orca showing on the right (from same 3mf)
Maybe this is a bug in the color mixing version?
Sorry, forgot to mention I am on Snapmaker Orca 2.3.3 - I’ll file a ticket and see what they say. Thanks! Is downgrading problem free?
I’m having the same issue, and downgrading to 2.3.1 seems to have resolved my issue! I’ll keep you posted if there are any problems with downgrading though
Looks like this was fixed in v2.3.4! Thanks!
It seems that every new release brings a new bug.
